Transmission Fluid Check
RPGR90s
Jerome
2019 Ford Edge ST
I have a 2019 Edge ST and wondering if there is a dipstick for the transmission?
Thank You
Spitfire
Alliance
OH
2018 Ford Edge
No dipstick. They say take it to the dealer to have it checked. Doing it yourself, the vehicle needs to be level (they say on a lift), remove shield, take out plug on the "side" of the transmission, if oil comes out, it is okay, if not, add fluid from the top cover plug till it runs out, then replace the plug...oh yes, use some thread sealer as the case is cast alum. and the plug is steel, dissimilar types of metal will cause it to seize.
WADave
Bothell
WA
2021 Edge ST
@Spitfire - Seriously? Or you just joking? There really is no transmission fluid level indicator?
