Setting up 2023 Edge ST to be towed flat behind RV
DRF1031
Goodlettsville
TN
2023 Ford Edge ST
I am setting up my 2023 Edge ST to flat tow behind an RV and have run into problems. I have installed the base plate but need to install wiring to the tail lights for brake, turn signal, and tail lights. How do you wire that since the lights are both in the body and on the lift gate? The 2nd issue is tying into the brake system so that the Edge brakes when the RV brakes. With the congestion under the hood, how and where do I get wires and vacuum lines through the firewall? Thanks!!
